Farmboy666
Sep 27, 2017Explorer
loggenrock wrote:
Low point drains do NOT drain the fresh water tank - that's another valve. Low point drains allow water in the lines to drain - you should have both a hot and a cold drain, in addition to the water tank drain. 3 total. I have a 2015 Prism 24J - the valves are small T-handles that pull up to open. Lousy placement, they are behind a panel in the under-bed storage compartment. They will drain onto the ground. Mine happen to be just behind the passenger side rear dual wheels. ST
My low point drain DOES drain my fresh water tank and everything below it so be careful with your blanket statements.
