Farmboy666
Oct 05, 2017Explorer
Bordercollie wrote:
"Low Point Drains" sounds like a terminology problem. Normally what are called low point drains function to drain water out of the hot and cold water lines when sanitizing the system. It may be Farmboy's rig has different labeling.
Not a labeling problem. My fresh water tank has only one way to be drained and that's through the low point drain which is the drain that is used to drain the water lines for winterizing. My tank is not down low it is up higher than anything else in the plumbing system and therefore uses the low point drain to empty.
38,782 PostsLatest Activity: Sep 18, 2026
