garyemunson
Feb 20, 2017Explorer II
First VERY IMPORTANT thing to do is bleed/flush the brake lines thoroughly with fresh brake fluid. Critical to do that to get rid of moisture that finds it's way into a brake system when it sits. Standard brake fluid is designed to absorb moisture to protect the metal parts but it will eventually get saturated and that is why brake fluid should be flushed on a regular basis.
