ApachefogExplorerSep 17, 2015Cold water faucetMy cold water works in the bathroom and shower but only hot works in the kitchen sink....Turn on the cold and nothing comes out...:h
GMandJMExplorerSep 17, 2015Is your kitchen sink on a slide? If so, is it possible that the cold water line is being pinched when you moved the slide? And if you turn off the hot water shutoff under the sink, you get nothing at all? Correct? Like others, I suspect there is likely an issue with your faucet.
Related ContentLippert faucet leaks, replaced with MoenDometic Servel RGE400 fridge too coldNo cold water from kitchen faucetOxygenics Fury RV Handheld Shower head --COLD dripNoticed warm water comes out of cold faucets. Why?
