Ivylog
Dec 04, 2014Explorer III
If the propane burner (or electric elements) cannot generate enough heat when it's below freezing the absorption cycle will not work... cool. If your refer stops cooling you need to block most of the cold air from getting in or add a light bulb to warm the back of the refer up. Unless you are traveling a long way, I would not worry about it MAYBE not working.
38,780 PostsLatest Activity: Aug 05, 2026
