aboeck3
Nov 17, 2014Explorer
cold weather travel
I am traveling from a warm Florida to a cold Missouri. If my tires are at the correct psi when I leave Florida do I have to check and add air when I get into cold weather?
Passin Thru wrote:
We ran heavy trucks for well over 3 million miles and never checked the air pressure from FL-MO-CA-MT or anywhere else from -50 to 130 F. We thumped them with a tire billy and if they all sounded the same we went. You can hear if one is low.
DannyLeininger wrote:rgatijnet1 wrote:
Yes. After each overnight stop check your tires in the morning before you hit the road and you will find that you have to add air.
I disagree with the above. The correct tire pressure is determined by the weight of your MH and set at about 70 degrees. As the temps drop, so will the tire pressure, but this is factored in by the tire designers.
If your tires are properly inflated in Florida, they will be fine in Missouri.
Do a search for How Tire Pressures are affected by cold Temps and you will find lots of info on this topic/
Enjoy the cold!
