aboeck3
Nov 17, 2014Explorer
cold weather travel
I am traveling from a warm Florida to a cold Missouri. If my tires are at the correct psi when I leave Florida do I have to check and add air when I get into cold weather?
rgatijnet1 wrote:
Reading some of the posts it is becoming very clear why some people have trouble with their tires. Of course, according to them, it is always the manufacturer's fault.
Maintaining proper air pressure at all times seems so basic and so important that it is preached by every tire manufacturer.
JimM68 wrote:
My tires have not loast any air, the air in them just got "smaller" is all...
Next spring it will get bigger again, and the machine will be happy.
Let's have some votes?
Should I:
A ignore the machine
B put air in the tires
C change the machines low limit so it quits *****ing
JimM68 wrote:
I also use a TPMS. With the current cold weather in Northern Illinois, most if not all of my tires are below the set threshold, and the TPMS is NOT happy.
Should I:
TempatureControlMan wrote:
Figure 1 Lb drop for every 10 deg drop in outside temperature.
