pianotuna
Nov 25, 2013Nomad III
Hi Snowman,
I've tested my system to -27 C (-16.6 f). I found out that the dash heater would prevent the furnace from running and then I'd have freezing issues. So I replaced the return air grill on the furnace with a fan. On my rv that circulates warm "living space" air under the cabinets and pushes some air along the furnace duct work. I chose to use a dual window fan unit which is controlled by a mechanical thermostat that lives beside the water pump next to the outdoor wall of the RV.
The fan unit draws just 23 watts and works better than a 1500 watt fan based heater which I tried using inside the cabinet.
38,768 PostsLatest Activity: Jan 26, 2021
