dougrainer wrote:
1. While Dometic is built in China, they are built to DOMETIC's specs and parts
2. Dometic was built in Mexico until the plant burned down a few years ago
3. Dometic was originally built in La Grange, Indiana until they moved the plant to Mexico.
4. According to BOTH RVP and Dometic, the higher failure rate has to do with mandated 410 instead of Freon 22 and the 410 runs at higher pressures and they had a learning curve on getting the compressors built for longer term operation( BLAME the Government for banning Freon)
5. RVP(Coleman) is built in Wichita, Kansas.
6. Dometic has the Lion Share of the business, so, you will see a higher failure rate.
who cares who's specs they are built to? They are still built in China! You can't hide behind a spec. All specs are negotiable in China, and a language barrier surfaces when you try to stay firm. You get alternatives shoved down your throat.
And manufacturers love to blame the government! It's like diverting blame to a common enemy you can both take comfort in, instead of coming up with a solution. At least the goverment is working a solution.
