- paddykernahanExplorerWe have a 22 foot Class C (B+).
It has a fold down Murphy bed that is very comfortable.
Murphy bed just takes second to deploy or fold back up.
We keep all of the sheets, blankets and pillows on the bed when folding up.
When folded up there is a full size couch to sit on.
Perfect for us.
- MysteryrnExplorerMy husband and I have a 24 ft winnabego View, I has a pull out couch only bed if not counting over cab. We basically live it in full time. We have a foam topper we store in overcab during the day. It has a blowup mattress that automatically refills. My Husband is 61 and heavy we both sleep comfortably. My only complaint is it is a pain to put bed up and down everyday but comfort is not an issue
- 1livermoreExplorerGreat ideas and info... thanks!
- houstonstrokerExplorerWe replaced out pull out sofa bed mattress with a new one from
Amazon. Big thick mattress plus an air bed on top. We also replaced our home sofa bed mattress with a memory foam mattress. I would sleep on either one they work great. - DrewEExplorer III
Solo wrote:
1livermore wrote:
We are considering purchasing a 20 foot class c that doesn’t have a rear bed. How comfortable is the pull out couch for two adults? Any info would help! Thanks
Our former Class C (to some a B+ with no overhead bunk area but, according to RIVA Definitions, a Class C on a cut-away chassis-the confusion comes from a cab-over area or not and a B being built on a completed van body)....
Indeed, the classes come only from what sort of a chassis is used to produce the motorhome, and hence what part of the wall structure was built by the RV maker and what part by the chassis builder
Class A -- a custom chassis or a bare chassis, the motorhome builder supplying all the walls. Usually motor coach conversions are also included here, for better or worse.
Class B -- a cargo van, with a motorhome built inside. Often the roof is raised and hence not original from the vehicle maker. (Logically I would think motor coach conversions ought to be class B's, but they don't ask me.)
Class C -- a cab and chassis or cutaway chassis, so the cab part comes from the chassis maker and the rest of the house from the RV maker.
Class B+, like super-C, is only a marketing term and not always precisely or uniformly defined. - hanford10ExplorerOurs is short in a 22 Gulfstream fits a 5'10 OK. I sleep better unfolded as the sections back and seat have different firmness.
- tobydadExplorerWe purchased a used 24' with a pullout bed thinking that it would work out OK. The couch pulled out to almost a full size bed that went all the way to the dinette. Naturally the slideout had to be out use the bed. The bed was so uncomfortable with nothing but a 2" mattress that we could feel the springs underneath. We had many enjoyable trips with me sleeping over the cab and my wife on the dinette. Make sure you pull out the bed and try it before buying.
- SoloExplorer
Our former Class C (to some a B+ with no overhead bunk area but, according to RIVA Definitions, a Class C on a cut-away chassis-the confusion comes from a cab-over area or not and a B being built on a completed van body), a Winnebago Aspect 23D, had a jack-knife couch which was the only sleeping area in that motorhome. As has already been mentioned, it was narrow for the two of us but, it worked. We added a memory foam topper that added considerably to it's comfort. It was doable for us for over 10 years but, a compromise no doubt. - valhalla360NavigatorComfortable pull out sofa bed = oxymoron
FYI: A class C by definition has the over cab bed but many are not rated for adults size people, so check it out the weight rating.
Jack-knife couches aren't that bad. We had one on our first boat but they tend to be narrow so not so great for a couple. - Cobra21ExplorerThe jack knife couch isn't bad at all. If it is the folded-up coach bed, the floor might be better.
Brian
38,778 PostsLatest Activity: Jun 10, 2026
