Handbasket
Jul 11, 2014Explorer
tylerdurdeno9 wrote:
Awesome, thanks for the reply!
Do you happen to have leaky rear windows on your xplorer? If you have one.
If it's a Dodge chassis, and has the single big rear door & window... My '99/'00 Roadtrek developed a leak at the rear. It turned out that most or all was because the rear door gasket had come loose at the upper passenger's side corner. There were some small plastic pins (yellow, IIRC) that protruded from the gasket and were supposed to locate & hold the gasket in place. On mine, about 5-6 pins on thet upper corner had come out of their holes in the metal, allowing the gasket to get out of place. I found that the pins would hod, so I added some 3M yellow gasket glue. Cured most of it.
Jim, "If it's called tourist season, why can't we hunt them?"
