base1957's avatar
base1957
compartment door latch 96 Wbago Vectra
Looking for two of these if anyone has any?
Bago no longer makes em
thanks in advance
9 101348-01-000EABOLT-SLIDE, LATCH - NYLON - W/SPRING & BRKT
http://www.winnebagoind.com/service/wincd/1996/96km34rq.pdf
  • DrewE's avatar
    DrewE
    Explorer III
    You may well be able to get used but serviceable ones from an RV salvage yard.
    Failing that, in your shoes I'd probably see about constructing a replacement part, say by cutting and drilling a piece of square aluminum stock. It doesn't look like too complicated of a piece: an angled end for the latch itself, a hole for the pull rod, and a hole for a cross-pin to catch the spring.
    One could also 3D print (or have 3D printed) the bolt of the latch once the design is reproduced in a CAD or other 3D design program; printing in nylon is possible but somewhat tricky and requires a printer more capable than the basic models (and likley an enclosure). I'm not sure PLA or other more common 3D printed plastics would hold up all that well here.
  • It in the "Technical Resources" => "Forum Posting and Help" subforum, third sticky down. "RV.net and Picture Related FAQs" posting.
  • in fact executive... i looked for the way to do that... and still cant find it ...the only way i was able to do it is because you sent the HERE link... where do i find that in this rv net site?
    thanks in advance
  • A picture helps more than 106 pages of gibberish. If you don't know how to post a picture, simply click HERE, put your picture in the box and copy the link provided into your post......Dennis
