dieseltruckdriv
Jun 06, 2015Explorer II
I put the same Honeywell learning thermostat that we have at home, into our 5er. It will learn how long it takes to heat or cool to the set temp, so it is at the temp you set at the time you set. I don't do low speed AC. If I have the AC on, I want it on high. It would be easy to add a switch to be able to select it if you would prefer that.
At home we have a 95% efficient furnace, and I wanted a "smart" thermostat to make use of it. It isn't "smart" by todays standards, but I only have to learn one thermostat this way.
