wa8yxm wrote:
If it is like my 2005 Intruder. then the problem is easily fixed...
Grab your box wrench set and crawl under the front, just in front of the right front tire, you will find the chassis battery,, Remove the POSITIVE bolt and clean everything (NOTE be careful even off the batteries at least one of these wires may be hot) re-assemble and try to start it.
Might as well clean the negative as well.
The problem and the possible (I will test over the next several years) solution.
Damon, put the WRONG KIND OF LUGS on the wire, instead of using a battery terminal lug they used common ring connectors, they react badly with the led of the battery terminal under moist or acid conditions.
The solution
When I replace my battery at the end of this month I plan on getting the shortest battery cable I can find, Ill put a bolt thrhough the lug on the cable and on the assorted freshly cleaned ring connectors,, I will then seal the connection well with a quality sealer.
THEN.. I will hook it back to the battery with a proper positive terminal lug.
Till then,,, Just keep cleaning every few years.
Good suggestion above.  I've solved a couple of no start problems for others by cleaning the positive terminal.
Generally, it's good idea to disconnect the negative (ground) terminal first.  That way, if your wrench slips and touches a metal part while still touching the positive terminal, bad things don't happen.
