wa8yxm
Apr 07, 2018Explorer III
Ok if it works on propane then it's getting the proper 12 volts. A bad board is the most likely suspect.
Dino boards are often "Multi-Fit" with eitehr jumpers or DIP switches that have to be set depending on the control board they are replacing.
Second: On the "Floor" of the outside compartment on my Dometic is a fuse/conneciton board, this is in addition to the fuses on the control board.
TRhose are 120 volt fuses. on the floor. DO NOT TOUCH as they are indeed exposed.
