enblethen
Apr 08, 2018Nomad
As stated by YC 1, you need to disconnect the incoming wires from the refer and test for voltage. Test each wire. Verify that the ground is good by testing to another ground source.Ground should be reading near zero ohms.
I would un-plug the refer from 120 volts AC to eliminate that system from effecting the readings.
