teddodd
Dec 13, 2014Explorer
computer reading
cannot make a connection to the computer outlet for my 2004 caterpillar journey. the outlet in the rear is not hot and cannot locate the one up front. any help would be appreciated.
teddodd,
Just wondering, what EXACTLY do you mean by computer connection? Are you talking about the Diagnostic Port, at the rear of the coach, just above the radiator? If so, there's one just like it, under the dash, most likely on the kick panel, under some wires and loom. Many have had a hard time finding the front one but, most did, after a bit of cussing.
And, if that's the one you're talking about, or even the rear one, I'm then assuming you have the 9-pin adapter connector.
Now, if those diagnostic ports are not what you're looking for and, in instead you're looking for a simple 12VDC power outlet, then there's some up front, or should be. I had to install one next to the bed in the rear to charge the wifes phone, her computer and, the camera.
Scott
