MountainAir05
Jun 09, 2017Explorer II
If you are a DIY then takes less than a 1/2 day to remove and take it apart and put it back together and install back in the RV. I have a 99 and did all of mine. I used a Super Spacer material that is use on home windows system. cost around 12 to $15 per windows depending on the window size. PM me if you need any info. There should be a lot of info on this on the forum but can not find it. I still have the Part Numbers for the products if you want them.
