ILVMYGT
Jun 10, 2017Explorer
BobGloria wrote:
Dave Root sells DIY kits - https://www.daverootrvglassrepair.com/
I have not used him but have heard good things.
I have used the kit and they work good. I did 3 windows and it took about 1 1/2 days. Remove the windows from the coach. Disassemble the frame and remove the window. I my case cutting the seal was the hard part as it had a metal strip in it. After the window panes are separated clean, clean and clean the panes. Rough up the edge for the sealer. Install the new seal/spacer then mate the two pane. Fill the edge with sealer. I let mine set overnight them reassembled the window and frame. Install in coach. You will nee a good work area like several plastic tables to lay everything on. Also I use a pickup truck backed up to the coach as platform to remove the windows.
38,780 PostsLatest Activity: Aug 05, 2026
