I had inside condensation on my front cap that would drip around my cabinets and dash. It turned out NOT being a leak from the outside but an area where the fiberglass batt insulation had shifted and left areas with no insulation at all. When we were in areas with a high humidity, like Florida and other coastal areas of the country, the difference in temperature from the outside to the inside would cause enough condensation to accumulate on the inside to look like a leak, dripping water and all.
I solved the problem by spraying foam insulation on the inside of my front cap.
I think it is a possibility that you may have areas that lack sufficient insulation and condensation develops on the inside surfaces of your coach.
