TyroneandGladys
May 21, 2013Explorer
If you have a sewer clean out just open and run your RV sewage hose to it and dump. Do not leave attached as you could run into code issues. If you do not have a sewer clean out or the one you have is not accessible to the RV check with a plumber for a price to add it to your line and do not call it a RV dump it is a sewer clean out only and after the SEWER CLEANOUT is there then you can use it for dumping your RV.
38,778 PostsLatest Activity: Jun 05, 2026
