JaxDad
Sep 25, 2021Explorer III
D3Cambo wrote:
Yes, the vehicle is currently insured with Full Coverage through Geico and passes all required Life Safety Items:
LP gas timed leak test at cook top burner
Ground Fault Circuit Interrupter (GFCI) circuits
Wall receptacles and ground fault
Hot Skin test on exterior
Emergency exit windows
Fire Extinguisher
Smoke/Fire Detector
Carbon Monoxide Detector (if applicable)
LP Gas Detector
Rubber grommet around LP gas line of water heater (if equipped)
Also it is not a boondocking only rig as it has shore power hook ups features and can be directly plugged into the appropriate outlet at any rv park. Also the shore power cord is included .
Glad you mentioned that JaxDad I will remarket appropriately.
Thanks again! Any feedback is most welcome!
I think you might have misinterpreted / misunderstood my comment.
HAVING the required life safety items is VERY different from being CERTIFIED as meeting all the required standards.
You are saying a registered group has certified that unit as being built to, and in compliance with, the required standards?
38,782 PostsLatest Activity: Sep 01, 2026
