moon.lake wrote:
Oh sorry, I meant converter! The brand I am not sure of at the moment. But does the converter only run the lights? Because in the georgie boy manual it says it will run lights and accessories, which I assumed meant the outlets.
Converter does absolutely nothing unless plugged in. Electric that works is running direct on battery power.
No 120v outlets unless you add an inverter. Accesories means 12v slide, 12v fridge controls, 12v thermostat to control furnace, 12v lights, 12v water heater control, 12v water pump, 12v fans, 12v radio.... etc.
