snowdance
Dec 09, 2013Explorer
If your water lines are inside and not hanging under the floor they should be OK if you keep it heated inside. Water tanks and holding tanks ect become a problem for most.. I got my tank and plumbing heaters here. Clicky
We are good to about 0F. But you will need to stay where you can plug in at night to not run your batterys down. They do not use a lot but need to be kept on any time you are in cold weather. They really do not heat the tanks but they will keep them warm but you need to turn them on before it gets to cold.
38,768 PostsLatest Activity: Nov 21, 2015
