Tom_Barb
Sep 14, 2015Explorer II
Corian counter tops,
How to repair, we have a broken corian divider between the washer and the drier compartments. Is there a good glue? It can't be seen when every thing is assembled.
Executive wrote:I am a cabinetmaker and the above pic is a countertop of a job that broke in transit. It was glued with the proper tinted 2 part glue and when I finished sanding it out (2000g) the 2 glue lines totally disappeared. In a place that won't be seen, regular epoxy will work-do not use Gorilla glue!
There are shops that can repair Corian pretty well. They glue the pieces together, then use Corian "dust" to fill the noticeable crack that will be there. Once set and dried, it's then sanded using several grits of sandpaper until it's smooth and clean. It's a long process and requires some skill but a lot of patience.
If you don't care how it looks, simply use a quality glue like Gorilla Glue. A LITTLE goes a long way and it will swell when applied, so use sparingly. Contact Cement works well also. Once you glue it, I would also glue a piece of aluminum underneath and across the break for added support....Dennis
