I have decide to go with the cork flooring in the MH, do you need a barrier under the cork. Is it glued or snap in place. wolfe10 posted on this but I don't remember if he said if glued or snap or ...
I would recommend that any time you pull up the old flooring, be it carpeting or whatever, that you coat the underlayment plywood/flake board with a polyurethane coating. You just never know when you may get a leak and this is cheap insurance against unnecessary damage to the floor of your coach if there is an accident.
