Fleetwood_Coupl's avatar
Mar 03, 2018
Correct AIr filter
time to replace the Air filter, thought it was Donaldson PN P533930 which is just the element, My filter is housed in what appears to be a sealed metal container. Can someone give me a sanity check on this PN# and or does the container open some how. 2006 Fleetwood Expedition Cat C7 engine.
  • nascar11fan wrote:
    Just replaced mine on my 2006 Discovery. Got it from filter barn.com for 81.99
    Thanks, just placed my order with filter barn, free shipping for any order over $100 so I ordered my fuel filters also.
  • Just replaced mine on my 2006 Discovery. Got it from filter barn.com for 81.99
  • Just a correction, many Monacos used an element only. My 2005 Diplomat with an ISL had a Donaldson housing that had a removable end cap. It was a rear radiator coach and the filter was in the electrical bay behind the driver's wheel. I really liked being able to just replace the element. I was able to see what the filter looked like when I replaced it and it was easy to replace.
    So can see the filter cover, on the right, in this photo:
  • Gadget Man wrote:
    Fleetwood Couple is correct, unless you're running a K&N filter, the filter element and housing are all one unit. Here are the part numbers for my C7:
    Baldwin PA3493
    FAR 114880-003
    thank you sir
  • Fleetwood Couple is correct, unless you're running a K&N filter, the filter element and housing are all one unit. Here are the part numbers for my C7:
    Baldwin PA3493
    FAR 114880-003
  • Ivylog wrote:
    Have not seen a air filter on a DP that you can just replace the element...have to replace everything.
    Thanks that's what I thought, just need the correct PN I guess.
  • Ivylog's avatar
    Ivylog
    Explorer III
