zach477's avatar
zach477
Correct order to disconnect dual batteries
I want to make sure I've got this right...
I've got two 6v batteries in series. Wiring is as simple as can be. One cable connected to the negative terminal on batter 1, another connected to the positive terminal on battery 2, and a third connecting pos on battery 1 to neg on battery 2. No other wires to worry about.
I know that I should disconnect the wire going to the neg post of battery 1 first. Then what?
  • zach477 wrote:
    So after that it doesn't matter which order?
    And then the same thing when I hook up new batteries, as long as I connect the negative to battery 1 last?
    Correct
  • So after that it doesn't matter which order?
  • Mmwtdh wrote:
    As soon as you disconnect the negative from the battery (1), all is dead....
    Correct. Disconnect the negative wire to ground (vehicle chassis) first and that way if you should inadvertently touch a positive wire to the chassis, nothing will happen. So, negative wire off the post first.
  • As soon as you disconnect the negative from the battery (1), all is dead....
