Busskipper
Dec 08, 2013Explorer
Casinojunkie wrote:
Wish to find out which might be cheaper to operate when outside temps are the same.
Electricity cost at .17c per KW.
Hot water heater, (Atwood 10 gal. GC 10A-4E) is on only when needed, can be used with propane and/or electricity.
Furnace propane (Atwood model 85311VDCLP), also have electric ceramic 1500w space heater, If needed.
Hope I have given enough info.
Thanks
These post always amuse me, everyone thinks that the 1 to 1 ratio + a 100% efficiency, but there is so much more that needs to be taken into account.
Most of us have a Heat Pump on the roof of the RV -- this is generally 300 - 400% more efficient than an electric heater, so it might pay to use the heat pump when the air temps are beneficial (usually above 32 F)
Take a look at the Wikipedia definition;
Wikipedia - Heat Pump
"Heat pumps are used to provide heating because less high-grade energy is required for their operation than appears in the released heat. Most of the energy for heating comes from the external environment, and only a fraction comes from electricity (or some other high-grade energy source required to run a compressor). In electrically powered heat pumps, the heat transferred can be three or four times larger than the electrical power consumed, giving the system a Coefficient of Performance (COP) of 3 or 4, as opposed to a COP of 1 of a conventional electrical resistance heater, in which all heat is produced from input electrical energy.
When comparing the performance of heat pumps, it is best to avoid the word "efficiency", which has a very specific thermodynamic definition. The term coefficient of performance (COP) is used to describe the ratio of useful heat movement per work input. Most vapor-compression heat pumps use electrically powered motors for their work input. However, in many vehicle applications, mechanical energy from an internal combustion engine provides the needed work.
When used for heating a building on a mild day, for example 10 °C, a typical air-source heat pump (ASHP) has a COP of 3 to 4, whereas an electrical resistance heater has a COP of 1.0. That is, one joule of electrical energy will cause a resistance heater to produce only one joule of useful heat, while under ideal conditions, one joule of electrical energy can cause a heat pump to move much more than one joule of heat from a cooler place to a warmer place. Note that an air source heat pump is more efficient in hotter climates than cooler ones, so when the weather is much warmer the unit will perform with a higher COP (as it has less work to do). Conversely in extreme cold weather the COP approaches 1. Thus when there is a wide temperature differential between the hot and cold reservoirs, the COP is lower (worse)."
So lets just be smart in the use of the resources we have available, when making decisions on heating options. Hard to beat 300-400% when it comes to comparisons on what is the most efficient. Let's not forget the Heat Pump -- someday I suspect Manufacturers will realize the benefit and begin to use Mini Splits in the RV lines, the new 20-28 SEER units are even efficient down to ZERO degrees F, and they push a lot of good WARM air as much as twice the efficiency as the older units.
Just a thought.
JMHO,
38,778 PostsLatest Activity: Jun 06, 2026
