mc_ccExplorerJun 18, 2015Cost for replacing Ring and Pinion rear end F3 chassisWhat should be an approximate cost for replacing the ring and pinion set on my F53 chassis. I was quoted $2300.00
wildmanbakerExplorerJun 18, 2015Did you check on what a rebuilt 3rd member would cost? Should only take about 2 hours labor to R&R the 3rd members.
Related ContentCoach/chassis battery replacementWater Heater Replacement RecommendationsRack and Pinion. Again!Replace insulation inside heater column.Replacing Chassi batteries
