valhalla360
Feb 19, 2021Navigator
The main engine block should be fine if you've kept up on oil changes and not otherwise abused it.
The concern I see is the ancilliary stuff. Belts, hoses, water pump, radiator, computers, etc... failing.
Then you have stuff like wires becoming brittle and does it become a challenge to find faults.
Eventually, even though the main core of the engine is perfectly fine, is it more hassle than it's worth.
38,782 PostsLatest Activity: Sep 01, 2026
