wa8yxm
Dec 05, 2016Explorer III
Short answer: YES!!!!!!!!!!
Longer answer: Most crock pots are well under 1,000 watts in fact many are less than 500 watts.. Well within the ability of your charging system.
Even better answer: Burton Stove to Go
This is a "lunch box" size device, like a lunch box it latches closed, it's also a slow cooker, runs on either 12 volt or 120 volt (i've lost one of my cords though) 12 volt is a bit iffy however.. i did install a HD 12 volt (20 amp rated) outlet with heavy wire (10ga) and a 20 amp fuse to run it. Fits very nicely in the small side of my sink, Works great for dinner for two.. (it is small) You can find 'em at some truck stops. We used to drop in a liner, (looks like a foil loaf pan, get it at the same truck stop) some chicken and stuff, Set it in the sink plug it in and ... By the time we were parked and set up.. Dinner was served.
Today it's one of 3 slow cookers in the house. and a Dutch Oven I can use as a Slow cooker on top of that. (Can you say I like slow cookers).
