barlow46
Aug 06, 2014Explorer
You also need to check the A/C compressor before you put a new belt on to make sure it has not locked up which may have caused the belt to come apart. More than likely the belt was just slightly loose and worn but there is always the possibility the compressor froze with the a/c clutch engaged. Did you have the dash A/C running when the belt came apart?
38,780 PostsLatest Activity: Aug 05, 2026
