I've read many various opinions on CAPS era engines. My conclusion was that many were damaged in the early years after the **** to ULSD from Diesel 2, due to lower lubrication. And while todays ULSD is advertised to meet all lubrication needs, and does for sure for engines designed to run on ULSD. My own opinion is that adding a lubricant additive, I use XPD, to each tank - is cheap insurance.
My second concussion, after talking to real nice veteran mechanic of diesels, is that CAPS do not handle fuel starvation well. The fuel both lubricates and cools the CAPS. A filter system that is partially clogged, can restrict adequate flow to the CAPS. Also at engine first start up, a failing or leaking lift pump, can also send a smaller supply of fuel then is needed by the CAPS.
Keeping filters clean (Sure right to do so on all engines!), either keeping the Lift Pump healthy/or/bypassing it and adding an aftermarket fuel pump (We have the FASS pump only, not the additive fuel filters, as I felt CC had good quality filters to start with.), and also adding a Lubrication additive to each tank - provides your best chance of keeping a CAPS up and running for a longer life.
And note my first post, suggesting that the non CAPS era ISL Common Rail with VGT was I felt a positive for a coach:)! So sure not arguing that CAPS era engines are not as easy to maintain as the CMR's.
Opinions vary, best to all,
Smitty
