Lurker1
Jul 12, 2015Explorer
I have a 2007 40' Itaska Horizon with the Cummins ISL. No DPF, EGR, DEF, etc. I assume yours is the same. Great, reliable engine, but you'll find the side mounted radiator with this year group was manufactured too small, and has trouble cooling when under significant load and when outside temp is high. Provided you manage this appropriately by keeping the RPMs high, you won't have problems.
I've driven some pretty significant passes (Eisenhower, Vail, and numerous throughout California), and can do them all in any outside air temp, but must take it slow and with engine RPM ~2500 when towing and when outside air temp is 90* or greater.
Interestingly, with the Cummins ISL, horsepower has changed slightly over the years as the emissions stuff was added, but torque has always remained the same.
