randallb
Apr 27, 2015Explorer
Motor mounts do not just break. They start to tear or settle. Both of these occurrences will give you some type of symptom. If it tears you should feel a shift from the power train assembly on take off. If they settle a driveshaft vibration is normally felt. If these symptoms are not noticed or ignored then what occurred to you friend is the final result.
Randy
Randy
38,766 PostsLatest Activity: Jan 10, 2026
