Sundance07
Aug 04, 2014Explorer
et2 wrote:Sundance07 wrote:
The new 6.7's run hotter for a reason. It is due to the EPA mandated emissions equipment. Hotter = Cleaner
But isn't that what the after burner and DEF is for? That isn't part of the cooling system to my knowledge. I might be blowing smoke, but it concerns me I'm significantly under weight 4,000 lbs on GVWR and 6,000 on GCWR, and the engine temps are were they are. I,m concerned if I had an additional 10,000 on the engine to pull, and still within its capacity according to the manufacture, I'm going to see it way higher.
To a point, the higher temp thermostats that are now in the 6.7 increase the engine temps which effect the whole combustion process. They want a higher engine temp for a more efficient burn, reducing soot which ultimately gets to your exhaust and emissions equipment.
38,778 PostsLatest Activity: Jun 10, 2026
