Old-Biscuit
Jun 18, 2017Explorer III
admiraljim wrote:
Do not believe I have a fuel shut-off solenoid. I think the ECM controls the injector pump. Ignition switch was checked and is OK. Thanks for the replies!
IF ignition switch was checked OK how is DC voltage getting thru ignition to ECM with switch OFF?
DO you have a tilt steering wheel?....pinched wire
Do you have any 'mods'....programmer or turbo delay ?
Have you tried holding your foot on brake pedal and then turning ignition key off?
Have you checked for 'codes'?
