pointrow
Mar 30, 2015Explorer
Ivylog wrote:
I'm a little surprised you have a 4000 tranny as most ISL's came with the 3000. Not downshifting between 65 and 40 is a programming problem... probably because it's programmed for 500 HP.
My combined weight is over 42K and I can climb most mountain passes at 40 in 4th without manually downshifting. On a long climb I will manually shift so if I have to let up on the throttle for traffic it does not upshift. I use the Eco Mode for rolling hills but not for mountains.
My bad it is the 3000.
thanks
38,780 PostsLatest Activity: Jul 04, 2015
