craig7h
Feb 13, 2018Nomad II
Last year I had my 30 footer stuck in the mud. The rear tires were up to the axel and the front not so much. I first off made the leveing jacks foot print bigger by placing many 2x6 so when I used the jacks they would not sink to far into the mud. I used the jacks to raise my unit up as high as possible then worked with wood to make ramps in the mud for the tires. I had to fill in the space left by the tires once I raised it. When all of that was done my neighbor came over with is tractor and very slowly pulled my unit out.
I would wait until your ground is dry, you cannot hurt it anymore now by just sitting where its at. Once the ground dries out do the above.
