Wrong_Lane
Jul 18, 2013Explorer
I was getting some spare keys made at a locksmith last week and noted they had a broad selection of "barrel" keys behind the counter. I took note because like you I own a Damon and that style key opens the doghouse and front engine access panel.
The locksmith said that if you have an original key bring it in and they can likely match or if no key bring the motorhome in and they would see what they can do to match things up. Worst case senario they drill out the existing and install new locks with keys.
You will eventually need to open those locks and it is way less stressful to deal with the problem at your leisure than during a crisis.
Good luck
Good luck
