Richard_999's avatar
Richard_999
Damon Owner need help
I just bought a 2002 Damon Challenger 348 ... and the slides , that worked on the lot / in Florida ..... Now will not work at home / in S. Carolina.
I do not have any fuse diagrams ... or ANY manuals.
I have checked the board near to front pump , .... fuse good - relay good - tight connections.
Checked all fuses ( that I could find ) .. in 3 locations in coach ... and Breakers.
Em. Brake = Down
Levelers off/ on switch in ON ... and lit
Tried key switch as ON / Off / On with engine running ... no results
Dealer not helpful so far.
Would appreciate any help - advice and/or copy of fuse diagrams.
Thank in advance ....
Richard / S. Carolina
  • WELL ... I got it to work ....
    ... BUT ... not sure how !
    I went in and did NOT put key in ignition .... and it worked !
    That defies all that I know about slides... but it does work ???????
    Not sure just how to feel about that !
    Still confusing ... anybody else have such a configuration ?
    Richard
  • RJL's avatar
    RJL
    Explorer II
    Sometimes it's alot like a puzzle. On my rig the key needs to be on, e brake set. Have you tried putting the levelers down? You have to try every possible configuration.
  • my buddy's slides wouldn't work unless driver seat was forward to hit a switch just like some the e brake need to be set.
