dougrainer
May 28, 2013Nomad
http://www.evanstempcon.com/tsg_RefrigerantChargeGuide.php
Copy and paste for the amount of 134a. Not SCS Frigette, but the parameters are the same.
Do NOT install a bypass. Clamp off BOTH heater hoses to the heater core and retest with hot engine. I will bet it blows cold. The ONLY thing that will cause your problem (IF the compressor is running) is hot water leakage thru the Heater core. Doug
38,769 PostsLatest Activity: Apr 24, 2002
