harold1946
May 28, 2013Explorer
Most of the P series chassis have the Evans tempcon valve and is a common cause for the symptoms described.
The way to test it is to have the engine up to temperature with the heat totally off. If the hose going to the heater core is hot on the outlet side of the valve it has failed and needs replaced.
www.evans.com
www.evans.com
38,769 PostsLatest Activity: Apr 03, 2026
