Sam_Spade
Sep 25, 2019Explorer
You have diagnosed it correctly.....mostly.
Mine did that occasionally just because of a lack of vacuum when pulling hard without downshifting. It got much WORSE when I loaded a "custom tune" because it tended to stay in the top gear longer.
There might be a vacuum leak but it might just be "normal" too.
Adding a larger vacuum tank or an aux. vacuum pump can completely fix the problem.
Not using the cruise control in hilly conditons can help too.
P.S. ALL of the RV shops I went to just came up with a blank stare.
I finally found a truck shop that knew what they were doing.
38,778 PostsLatest Activity: Jun 07, 2026
