dodge_guy
Oct 01, 2019Explorer II
MHancock wrote:Krusty wrote:
Yes, its a vacuum leak. Have a look under the hood for a vacuum reservoir. Test it for leakage. You will need a vacuum pump for testing. Also have a look at any vacuum lines for cracking etc. You may have a vacuum check valve near the reservoir. Test it as well, when they get worn, they don't hold vacuum well.
thanks, will do.
Yes, this is where you need to start. These HVAC systems are very easy to diagnose.
38,781 PostsLatest Activity: Jul 20, 2026
