buystockinfun wrote:
Richard, thanks for the information on the compressor I didn't realize that that was the method to figure out the exact type of oil. Probably saw why some oil was added to begin with. Interestingly an RV dealer told me that they've seen systems take up to 10 pounds though I believe Doug said my system should only hold 4 lb.
As far as the dryer so you're saying I may need to replace the dryer. I'm supposed to use a wire to replace the dryer or are there fittings that need separated in the system evacuated and all of that? Or maybe you mean to do something with the expansion valve screen. It's my understanding that's all sealed and you would need to replace the expansion valve but is there a way to unclog it or do something with this screen with a small wire? Not sure I completely follow that.
When I say needle now I guess I mean is it a valve stem you know like the little valve stem thing inside of a air fill they look the same in the inner tube or your automotive tire as they do inside of those air conditioners the connector for the low and high side.
Thanks again so much
Let me try this again. The inlet of the expansion valve has a screen that some times gets clogged. After depleting the system, you take the hose fitting off the inlet side of the expansion valve. Look closely inside the valve and you will see a screen. If you see debris, remove the screen with a small bent, pointed wire and clean it. If there is debris in the system then the receiver/dryer will need too be changed, as it also filters the system. The receiver/dryer is a round tank with fittings on both sides, at the top. Remove fittings and loosen the clamp.
The needle that you mention is a schrader valve, very similar to a schrader valve in a tire.
As far as the refrigerant capacity of diesel MH systems, the location of the condenser is the major contributing item. If the condenser is in the rear, then the liquid line runs almost the full length of the MH. If in the front, then the liquid line is much shorter and less refrigerant is required.
To address the word "FREON". Freon is a DuPont trade mark and does not describe any chemistry. R12 & R22 are not FREON, they are dichlorodifluoromethane & difluoromonochloromethane. Where as 134A is Tetrafluoroethane. The word "refrigerant" covers the whole array of chemistry and is the word most normally used by trained technicians.
Richard
