Thanks for all the replies.
I suspect the problem may be elsewhere but, on the other hand, it's pretty cheap and easy to replace the refrigerant so I'll see what happens.
The condenser fan is working properly, the clutch seems fine and I can see the pressure change as the TX valve does it's thing. Pressure is highest when the system has both AC fans running on high speed and drops to ~320 psig when the fans are switched to low speed. It cools very well with the outlet ducts showing ~48F at 90 F ambient
This all suggests I have a slight restriction someplace and I'm just hoping it isn't an issue with the hose deteriorating.
