hypoxia
May 10, 2018Explorer
Ranger Smith wrote:
If the bearing fails you are stranded on the side of the road.
The clutch bearing is not associated with the oil or refrigerant in the system. It is a seperate component mounted in the clutch assembly.
Loss of refrigerant or oil will have NO effect on the operation of the bearing.
A leaking front seal will cause loss of refrigerant resulting in the low pressure switch disengaging the clutch. No damage will occur.
38,782 PostsLatest Activity: Sep 10, 2026
