jyrostng
May 10, 2018Explorer
IBcarguy wrote:Cobra21 wrote:
If it is leaking refrigerant oil it should also be leaking freon. When it gets lower on freon it will most likely shut down the compressor. Then it shouldn't cool or damage the compressor.
Brian
X2 - this is correct
The bearing has nothing to do with the clutch, it's mounted inside the pulley separate from the clutch, whenever the pulley turns, the bearing turns also. When the bearing is going bad, it makes noise, even with the compressor clutch not engaged. a separate issue from a oil leak
38,782 PostsLatest Activity: Sep 10, 2026
